What CCTV system should I get
dabe
Hi I'm looking to get a 16 channel CCTV system for a pub but not sure as to what system to get (there are so many brands) they will be for indoor and outdoor use the old system is poc but I can upgrade to poe if needed any help would be appreciated
Many thanks
Hi @dabe
We would recommend Hikvision as the most cost-effective option for a 16-camera system.
If you already have lots of COAX/Analog cable run through the property, the easiest and lowest cost option would be to look at a Hikvision TurboHD Analog System.
Traditionally, analog solutions have been technically inferior to the latest Network IP products, but the latest cameras & DVRs from the TurboHD range now support many of the newest features (e.g. 4K/8P, ColorVu, AcuSense, etc...).
